Hi I am having some problems that I think are linked to the battery optimization. My transistor app is stopping working after about 3 minutes. Sometimes I dont get whatsapp and sms notifications until I open the app. I have been trying to access the battery optimization through settings, app drawer and ‘extras’ as suggested on forums but cannot find any of them. I am using the Inkos launcher. Any help appreciated.
@gez If you’re using the inkOS v0.4 the system shortcuts are located in AppDrawer settings now.
It’s duraspeed who is making your app stop.
Go to developer options and search for Duraspeed, and then check Tranistor app to allow it to run in the background.
hey thanks gezimos, ive just noticed im in version 0.1. So I need to…?
ok v0.1 doesn’t have those shortcuts.
but u can access Duraspeed in developer options you don’t need inkOS for that.
go to Settings / About / Build number and tap until it requires you the passcode.
enter your passcode, then go to Settings / System / Developer Options.
In search type Duraspeed. Tap on it, Open and then find Transistor and toggle it on.
couldnt find passcode so i downloaded version 0.4. and Ive sorted it im pretty sure. Thanks again gezimos
