Atlas review by wander
Atlas — Community App Review
Version: 0.1.1
Atlas is an offline map of the world for the Kompakt, built from CoMaps.
Download the regions you want over Wi-Fi. After that, search, routes and guidance all work with no connection, by car, on foot or by bicycle.
While you drive, a card covers the map: the next turn in large type with its distance and the road’s name, the two turns after it, the speed limit and your speed. Map shows the map, which moves in steps rather than gliding; Turns goes back to the card.
Home is one tap from the map once you have set it from a place’s page, and it heads the Favorites list. Search opens on the places you last drove to. Planning a drive offers the fastest route and one that keeps off the highways.
The map is drawn for E Ink: black-edged roads on white, place icons in ink, and nothing that glides, fades or tilts. Places can be saved in lists, and the lists imported and exported.
The map data is OpenStreetMap’s, from CoMaps’ servers. Atlas goes online only to download the maps you choose; your position, searches, routes and favorites stay on the phone. Turns are spoken only where the phone has a speech engine installed.
It asks for your location. The download is about 75 MB, and each region’s map is added to that.
Source and license: GitHub - wanderwildwood/chizu: Atlas (地図 chizu) — an offline map of the world on an E Ink phone, built from CoMaps: download a region, then search it and drive, walk or cycle with no connection. A card shows the next turn in large type while you drive. · GitHub — GPL-3.0-only, with CoMaps’ Apache-2.0 beside it.
Review for version 0.1.1
User rating: ★★★★★
I was excited to try this, after CalmMaps/PaperMaps stopped working for me, but the app crashes after I download the world view map. And I cannot skip this step either. Hope you can fix it, the screenshots look great!
Thank you for trying it and for telling me, and I’m sorry it stopped on you. I found the cause this morning: on a new install, the help that shows while the phone looks for its position asked the map for its state before the map was ready, and that closed the app right after the world map download and on every start after it.
It is fixed in 0.1.6, which is out now: Release v0.1.6 · wanderwildwood/chizu · GitHub
Install it over the one you have and it should open straight to the map. If anything else gets in your way, tell me here.
User rating: ★★★★☆
I’m very excited for this, I was really wanting to make Organic Maps/CoMaps work on the Kompakt. But this one’s got the same issue as the other two did, for me (or I guess more of a point of personal confusion, I know it’s not a bug) - the “needs a speech engine” aspect. How do I add that? It’s not an option within the app itself so I’m unclear on how I’m supposed to add it.
User rating: ★★★★★
Great, the app doesn’t crash anymore!
I noticed something else: when I open the settings, sometimes the top setting disappears after a second. I’m not sure whether I’m not supposed to see this setting or not. I can make a video of you need more clarification.
User rating: ★★★★★
I am super psyched for this, as Calmmaps was a bit unsuitable for hiking and I still used organic maps a lot. Thank you so much for creating this, so far the first tests have been working perfectly.
Yes! Let me know how it works for you on your hikes! :smiley:
It’s the 3D buildings toggle. I noticed it too, and your message was the nudge to go back in and remove it more thoroughly. Thanks!
Thank you for trying it. That speech-engine message was a remainder from my efforts to get voice into the app. Voice may still come down the pipe, but it was a bit more than I wanted to get into right now. In 0.1.7, out today, the voice settings are gone, so Atlas no longer asks for a speech engine; directions show on the screen. Release v0.1.7 · wanderwildwood/chizu · GitHub
User rating: ★★★★★
This one yes, but I noticed it in more settings tabs:
  • In power management: mobile internet
  • In advanced: Enable logging
  • When opening the settings menu: OpenMaps street profile
User rating: ★★★★☆
Understandable. I will simply make do without voice directions in the meantime then. The map itself is absolutely the best one I’ve tried on Kompakt so far.
User rating: ★★★★★
This is shockingly good. Thank you.
User rating: ★★★★★
Once again… what a great app, Wander!! The only thing missing would be an option to display km/h instead of miles per hour. Is that possible? Or am I overlooking something,… again :smiley:
User rating: ★★★★★
I tried Atlas on my Kompakt and it’s really well made, great job! I’ve been working on a similar project for a while myself, but I’m not happy with the design of my app yet.
Keep it up!
It’s there already: Settings, then Navigation, and switch off “Miles and feet”. Speeds and distances then show in km/h and kilometers. That switch is an awkward way to put it, so the next update makes it a plain choice between mph and km/h.
Thank you, that’s kind of you to say. Good luck with yours; I’d like to see it when you’re happy with it.
You were right, there were more of them. Those rows were meant to be hidden and showed for a moment before going away. Since 0.1.8 they are hidden before the page opens, and 0.1.9, out today, settles one more row on the Advanced page: Release v0.1.9 · wanderwildwood/chizu · GitHub
That update is out now. In 0.1.9, Settings, Navigation starts with mph and km/h side by side; choose km/h. Release v0.1.9 · wanderwildwood/chizu · GitHub
Review updated by @wander
  • Version: 0.1.1 → 0.1.9
  • Description updated
  • Checksum: 79b70dab9b3ffc718d426f6445b3252a51d4ddf2d1ac38e15cb96c3bffa4fa4d → 37dd96fbfa57f7484efb9ea267f184092ab9f161547eaa16874d5e7938d673a3
View current review
View current review
