Atlas review by wander
Review for version 0.1.9
User rating: ★★★★★
I went hiking, using the Atlas app twice now and it worked very well!
There is one issue/feature request that I have, though I am not sure if this is a general problem in CoMaps:
Sometimes I want to walk part of a specific trail, which I download as a gpx. After importing, I can see the trail on the map, but when I create a route, it chooses the quickest way and there is no way (at least I didnt find one) to make the route follow along the gpx-way (without making tons of extra points in the route which is a bit of a pain, especially on the slow e-ink device). Would that option be possible?
Glad it served you well on the trail. You are right, there is no way yet to make a route follow an imported trail. I am working on that for Atlas and will write here when it is out.
User rating: ★★★★★
I saw that you already implemented a function to use a gpx as a route. Thanks for the great and quick work! I wanted to ask if it would still be possible to implement, that you can also make your own route follow along a gpx. I hope you understand what I mean. For example I have a gpx of a whole hiking trail, but I only want to make a day hike route follow along that path or I am slightly away from the gpx path and still want to create a route which leads me to the gpx path and follows it. I attached a screenshot (in the screenshot I would want the app to say something like “follow gpx route”, so I could walk from Jena to Porstendorf along the gpx route, not the whole route and and not the direct route). Do you understand what I mean? If not just tell me and I can try to explain it in a better way.
