WiFi calling on Kompakt
After updating MuditaOS K to version 1.6.0, the VoWiFi feature stopped working for me.
Is there any information about this?
WiFi Calling? OR VoLTE? Because I’m not 100% clear which feature you’re referring to.
Can you please check if you have these settings enabled?
Yes, I mean Wi-Fi Calling (also known as Voice over Wi-Fi = VoWiFi).
I have the options from the photo enabled.
Thank you for the clarification. I will ask the team about this.
@Reverso Our team replied & they said that it might not be related to the update. In random moments - your carrier handshake might not success. We see this all the time on this forum.
Did you happen to set your APN settings manually? If you set APN manually, yes, it can be changed by update, but also a restart, ejecting sim card, inserting sd card, or just moving between countries, losing power, airplane mode etc.
Default APN (Plus internet) is selected. No changes was made
An analysis of packets sent by MuditaOS shows queries to connectivitycheck.mce365.one and connectivitycheck.mudita.com, with valid responses received (18.195.199.48, 18.199.200.16).
Then, after approximately 40 seconds, it queries the same addresses again. There are no queries for domains related to the operator’s ePDG/IMS. Furthermore, there are no UDP 500/4500 packets, meaning an IPsec connection is not being established.
So, your on the Polish PLUS network? Just asking because I have a Plus SIM card as well & maybe I can also try troubleshooting.
When you say:
Do you mean logs? Are these the logs requested by customer service? Did you reach out to them?
Yes, I use the Plus GSM network (Otvarta).
I checked the logs on my router because, as I mentioned earlier, the issue with Wi-Fi Calling not working appeared after a system update.
@Reverso
I think this case might need to be reviewed by out tech support. There was another similar issue reported some time ago & I believe our customer support solved it, but they did have to review the logs of the device.
