Whereabouts — Community App Review
Version: 0.1.22
Whereabouts finds a Kompakt that has gone missing. It sends the phone’s location to a server you run, encrypted on the phone before it leaves, so the server keeps it without being able to read it. From the server’s web page you can see where the phone is, make it ring, or lock it. The same commands work by text message, with no server at all.
It is FindMyDevice, reshaped: it cannot take a photograph, and it wipes the phone only if its owner has switched that on, with a password of its own. Most of the code is Nulide’s, and the protocol and the encryption are theirs.
The server half is also shared. Whereabouts server is FMD Server with a map of the people who share their location with you, a partner’s Kompakt or a teen’s iPhone through the Overland app, and a plain black-and-white page you can keep as a desktop app.
On the Kompakt, a service called DuraSpeed closes installed apps soon after the screen goes dark. Texts still work, but regular uploads need Whereabouts switched on in its allow list, once. The setup guide has an Open DuraSpeed button that goes straight there, and the Setup warnings screen says if it has stopped.
Hey! Quick question about how this app works. Once installed on my Komapkt, would it run in the background nonstop? Have you seen any impact on battery life? Does it provide a constant updating GPS to the home server or is it every so often?
Regarding the “home server” is this something I’d need to setup myself? I’m assuming so, I have a headless pc running Zorin OS and figure it’s a good candidate, though just wanted clarification on what steps I’d need to take to do so. Appreciate you!
Review for version 0.1.23
@spencersabo thanks for asking. It isn’t constant GPS. Whereabouts uploads in the background every X minutes, and you choose X under Background location upload interval in the server settings (below 15 minutes isn’t recommended). The longer the gap, the less battery it uses. On the Kompakt, DuraSpeed closes installed apps after the screen goes dark, so Whereabouts has to be switched on in its allow list once: the setup guide has an Open DuraSpeed button, and Setup warnings tells you if uploads have stopped.
Yes, you run the home server yourself, and a headless Zorin PC is a good fit. It is the Whereabouts server (a fork of FMD Server) in Docker, and the steps are in the README of https://github.com/wanderwildwood/ibasho-server: clone it, docker build, docker run. It needs HTTPS (the app refuses plain HTTP), so put it behind a reverse proxy such as Caddy with a certificate. With no server at all, the same commands still work by text message.
It inspired me to set up a home server on a desktop that wasn’t getting much use. It took some learning and assistance from Claude. Now it will also host nextcloud storage for my family.
Once it was all set up, it found my location quickly. Pure GPS was most accurate in my location.
Oh that’s such a great compliment!! And way to go on the Nextcloud switch! Be careful, the home server is a rabbit hole!
This app is one of my more experimental ones, so please feel free to send any feedback you might have <3
