And how does it work.
Here and there, for example in the settings of
MuditaCalendar, I heard about Duraspeed. Can someone please explain me what it really is and how to set it to limit the drain of the battery. Thanks in advance.
Ok, thanks.
And where do I find the settings of Duraspeed?
For the moment I use InkOs that let me kill the apps that I don’t want turning in the background.
Go to settings → Developer Options, and click the search loupe at the top and enter “Duraspeed”. Then you can select which apps you want to add or remove.
Ok, and if I add it, what will that do? Allowing the app to run nonstop?
