Voice review by mudita.com.phony709
Voice — Community App Review
Version: 1
This is a review for the current as of may 2026 version of Voice audiobook player. I got it through the aurora store.
The all works very well. its very simple, well suited for kompakt interface. The only hiccup is that the app has a “shake to reset” function which works as follows:
  1. You start playing audiobook and set a sleep timer to, say, 10 minutes, so that after 10 minutes the audio fades out and pauses.
  2. Once the audio starts fading, or for a few minutes after, you can physically shake the phone to rewind the playback a little bit and start playing for another ten minutes. This is nice because you shouldn’t need to turn on the phone screen to do it, looking for the playback button on screen
In case of kompakt, the shake only registers when the phone is unlocked, making it quite a bit less practical.
Oh, I also had to do some wizardry in developer options to prevent the OS from killing the app all the time.
