I am looking into changing cellphone plans from Dumb Wireless and it seems US Mobile might be a good fit. Are there any Mudita users have used US Mobile and would recommend?
Works fine for me. I usually use the Light Speed (TMobile) network, but have also used Dark Star (AT&T).
Curious if you’re using their eSIM or physical card? I too am on US Mobile but have only tried physical SIM.
I use US Mobile’s Light Speed service with both physical and eSim in my Kompakt. Not both at the same time though. Either works fine. Just make sure to create a “Light Speed” APN per their support page.
I use US Mobile’s WARP network (rebranded Verizon) with my Kompakt. I have no complaints about US Mobile; it has been reliable and cheap! Edit: I use a physical SIM card.
I’m using Dark Star since I got my MK and it works flawlessly. Yes, make sure your APN settings are correct–this is very important! I use the physical sim card
I’ll also add that if you cannot change an APN profile, add/create a new one.
Hey guys- thanks for all the input. It has been helpful.
I went through with the switch and I am now on the US Mobile Dark Star network. It has proven to be the correct choice.
Wish you all the best!
