Hello, and thanks for making a great product. So far I’ve only had one issue I haven’t been able to resolve. I’m a T-Mobile customer in the United States, and haven’t been able to send or receive SMS after transferring a SIM card I previously had in an iPhone. After doing some research, it appears I might need to edit the APN information as described here: BYOD T-Mobile data & APN settings | T-Mobile Support
Unfortunately their APN hostname contains a dash, which I don’t believe I can type using the current numeric keypad, as that character is not available under the “1” key. What should I do to fix SMS on my Pure so I can switch to the device full-time? Thank you.
You’re right special characters will be displayed with a long press on * key, but it appears only to work for writing messages. Unfortunately, it’s unavailable for APN settings. Tried this myself but maybe you or someone else can confirm?
Checked with MuditaOS v1.2.0, the current one for Mudita Pure.
Annotation: When looking up the information about LONG PRESS for SPECIAL CHARACTERS in the Mudita Pure manual PDF, it cannot be found by a text search. You’ll note it just by reading thoroughly the manual. On page 8 there’s a matrix shown with a column named LONG PRESS and the indication SPECIAL CHARACTERS for KEY *. I guess text search for that area doesn’t work because this matrix is embedded as image not as table with text.
@trinque I’m going to ask our tech team about the APN settings. However, please let me know if you got a new SIM card from your provider or is the SIM card that you’re using the same one that you took out of your old phone?
I just wanted to circle back and mention that I was able to resolve this problem. I first acquired a new T-Mobile SIM card. That didn’t work at first, so I performed a factory reset. After that, SMS works perfectly. I’m happy to be switching to this device as my daily driver now. Thanks for the suggestions.
I was wondering as a fellow US T-Mobile customer, if you’re able to call and text on the Mudita Pure regularly. This seems to be a recurring issue with others, but you sound like you’ve made it your primary phone.
