Hi,
I’m in the UK. Just pre-ordered without thinking to check which carriers are compatible with the phone. Now I’ve looked at the FAQ and it only lists a few carriers, non-UK.
I’m with the Phone Co-Op which uses EE. I’m not interested in changing providers.
Will this be compatible?
Thanks!
@bethmaiden Thank you so much for your order and thanks for reaching out with you question. I will check on this you. There shouldn’t be a problem because the Mudita Pure has a universal SIM module, so you should be able just to pop in a SIM card & it will work. We know that the following carriers are supported in the UK: 3 (Three), EE, O2 & Vodafone, however, I will verify that there are no expected changes after Brexit.
