When i go to settings/Sound/Advanced…at the Mudita Kompakt i noticed that i don’t be able to mute key and touchsounds when i try to call someone.
Is it possible to do that anyway?
Also in advanced settings i see the third option “Sounds and vibration time…”
What does it mean? It seems when i turn it off the problem above do not solve this.
Let me make sure I understand what you’re trying to achieve. When you press the dial pad (calling someone) you want that to be silent. Am I understanding that correctly?
Yes i want to silence the sound when i dial a number.
When i go to settings →Sounds→Advanced i can turn off “"Touch Sounds” but it doesn’t affect to my phone.
I still get a loud sound when i hit any number on the dial pad.
It is also strange for me that you have an option “Dial pad tones” but not me.
My latest update was Mudita OS 1.5.
Did i miss something?
As you can see, there are different options on Setting→Sound→Advanced.
In my language dutch te option Dial Pad Tones is not available.
Proberly there al more languages with these problems.
