Today review by mosquishe
Today — Community App Review
Version: 1.0.0
So I went looking for a to-do app on my Kompakt and there just… wasn’t one. Genuinely surprised me. I basically lived in Things3 on iOS for years, so I figured I’d rebuild the bits of it I actually used and make them feel right on e-ink.
What it does:
  • opens straight to today’s to-dos
  • plan things for a later date (they only show up once that day arrives), and see everything ahead in Upcoming
  • checklists inside a to-do (groceries → the actual items); tick them all and the to-do can auto-complete itself (you can disable this in settings)
  • tags, deadlines, repeating to-dos, and a Logbook of what you’ve finished
  • you can set when “today” actually starts (mine rolls over at 3am)
I built it for myself first, so it does what I need and probably misses stuff you need.
Which is kind of why I’m posting it. I’d really like to hear what you think, what’s missing, what feels off on your device. Tell me and I’ll have a go at fixing it.
Review for version 1.0.0
User rating: ★★★★★
Great app! Thanks mosquishe
I was also a fan and daily user of Things 3 on mac/iphone. So I love this basic Eink version of it.
The only thing I’m missing so far is the possibility to add a reminder.
For example to set a reminder for 11:00 today to call my dentist.
Maybe similar to the reminder / notification feature in the native calander app on the Kompakt?
I wonder how you think about this and whether you see a possibility to add this feature…
I tried the app, and it worked nicely till I started using tags, and then it crashed and I couldn’t start it again.
Review updated by @mosquishe
  • Version: 1.0.0 → 1.0.1
  • APK Link: https://github.com/Yvdriel/mudita-today/releases/download/v1.0.0/today-v1.0.0.apk → https://github.com/Yvdriel/mudita-today/releases/download/v1.0.1/today-v1.0.1.apk
  • Checksum: 0e8cdb16def6c54f0e79eb21358612d419e4198caabce8faeca81f24578fb0fc → 407171e2aa2b29a4bc0e98e9e4ff04f169d2898526c2baa050e2337e60e2b87a
View current review
Review for version 1.0.1
Thank you for your feedback!
You were the second person mentioning this, I just released a new version with some bugfixes and improvements:
Fixed
  • Crashes and force-closing
  • Scrollbar disappearing at the bottom of New to-do and Settings
  • Task list going blank when tags exist
  • Tag creation breaking the app
Added / changed
  • Tick checklist items from the home list
  • New to-do reordered: checklist under notes; when, deadline, repeat, tags at the bottom
  • Clear the logbook, or auto-keep only the last 30/90 days
  • Title-less to-dos show “Untitled”
Thank you for your feedback Jurjen!
Amazing to see that you like the app so far :smiley:
I like the suggestion, I will probably use that myself as well. I’ll see if I can add it in an update the coming week.
  • Version: 1.0.1 → 1.1.0
  • APK Link: https://github.com/Yvdriel/mudita-today/releases/download/v1.0.1/today-v1.0.1.apk → https://github.com/Yvdriel/mudita-today/releases/download/v1.1.0/today-v1.1.0.apk
  • Description updated
  • Checksum: 407171e2aa2b29a4bc0e98e9e4ff04f169d2898526c2baa050e2337e60e2b87a → 3416ca03a2d23e332c6699d815862ceb0c6bf7e27c4e62a5bba72ace1eb5f00c
View current review
Added
  • Reminders — set a time on a to-do and get a notification when it’s due; tap it to open the to-do. Works like Things 3: the reminder is a time on the task’s “When” day, and adding one to an undated to-do schedules it for Today. Recurring to-dos carry their reminder to each occurrence.
  • Lock-screen alerts — a reminder lights the screen and shows a full-screen card (Open / Dismiss) on the lock screen, since the Kompakt otherwise keeps third-party notifications off the lock screen.
  • Pick your reminder sound — Settings → Reminder sound: choose from the device’s notification tones, with a tap-to-preview.
Changed
  • Opening Settings no longer pops up the keyboard — “Day starts at” is now a tap-to-open time picker.
  • The reminder-sound list opens fully instead of half-open.
  • “Keep completed to-dos” options no longer wrap onto two lines on the narrow screen.
@jurjen I had some spare time today, so took the time to add the reminders :slight_smile:
Review for version 1.1.0
User rating: ★★★★★
Awesome app. I love the look and all its functions - works great for me! Thanks for creating it. :blush:
User rating: ★★★★★
Now it works as it should, very useful app.
User rating: ★★★★★
Great!
Just installed the update, tried it, and it works perfectly :slight_smile:
I also like how the checklist items or shown in the Today screen now.
Good work mosquishe, thanks!
User rating: ★★★☆☆
I am liking it so far, however I ran into a bit of a bug while trying to make a list. I was attempting to make a packing list, but as I add more items the “add item” prompt moves further down. I try scrolling to move to it, but it keeps going too far, I have found I am able to find the prompt to add another item by very carefully tapping on the scroll bar just a little bit, but it becomes more difficult each time. Perhaps you could implement a better system of scrolling? It would be especially helpful for making long lists like this. Great app, keep up the good work!
User rating: ★★★☆☆
Unfortunately I don’t know how to get this app to start up and run in the background, so the reminders never ring or pop up on my screen. Does anyone have a fix for this?
