Does anyone know how to change the sound level of the mudita Harmony 2 clock? The clock started sounding very quiet after the update.
Are you changing the alarm sound or the relaxation sound?
If it’s in the Relaxation, then once the audio is playing, just turn the big top knob, either one way or the other to either increase or decrease the volume.
For alarms- the volume options are directly in the main alarm settings.
Thank you for the answer. I can’t find, how to change the alarm sound. When I press on „Alarm“ it takes me direct to the setting the alarm time and after setting the time it’s over.
And after this I am on te main screen
So how to get to Main alarm volume?
Thank you!
