Speedometer — Community App Review
Version: 0.1.6
Speedometer shows how fast you are going, how high you are, and what the air is doing — on one screen, with nothing on it that is not a reading. I made this app because I drive a kei truck and needed a mph readout.
- Speed in km/h, mph, knots or m/s. Press it and the number fills the screen, for a phone propped on a dashboard or clipped to a handlebar.
- Altitude in meters or feet, from the GPS.
- Position in degrees, minutes and seconds — the form you can read aloud or write down.
- Air pressure, pressure at sea level, and pressure altitude, from the phone’s barometer.
It holds nothing between one run and the next except the units you chose. There is no map, no trip log and no account, and it asks for no network permission, so your position could not leave the phone if anything asked it to. The GPS runs only while the app is on screen.
Two readings are labelled for what they are rather than what you might assume. Altitude is above the WGS84 ellipsoid, not sea level — Android can convert between them only from a later version than the Kompakt runs, so the screen says which one it shows. And pressure altitude is what the height would be on a standard day, which on a low-pressure day disagrees with the GPS by a hundred meters. Neither is broken. Nothing here is accurate enough to navigate by.
It is after Blue Square Speedometer by nhirokinet, whose unit and atmosphere maths it carries.
Source, and the licence: GitHub - wanderwildwood/sokudokei: Speedometer — how fast, how high, and what the air is doing. For the Mudita Kompakt, with nothing on screen that is not a reading. · GitHub — GPL-3.0-only.
