Some notes for future updates
I think it would also be great if there was an option to drag down on the screen with the phone locked, so you can change sound or brightness without the need to unlock the device first. And maybe another suggestion is for the calendar: it would be nice if I can set a reminder for appointments like an hour or day beforehand. I’d rather not check my phone unless it is necessary, but without proper reminders in the calendar I need to check it daily (something I keep forgetting.)
Also a little note about the maps app: the voice in Dutch is a little weird, there are some clear mistakes. The biggest one is the pronunciation of numbers. For example: 26 should be said as zes-en-twintig, but is is said as twintig-en-zes (pronounced the other way around.)
I love the recent update so far, and I look forward to what else will come to make the device even better :slight_smile:
P.S. Customer support seems either busy or forgetful, I don’t know which. I am currently waiting for nearly a month to get everything set up to be able to get my screen repaired. The reply’s have stopped. I genuinely hope to get a reply soon.
I’m sorry that you are experiencing a delay. I will check on this for you.
