Some bugs i've found while using Kompakt
Hi, i’ve been using the Kompakt for a while now, and i’ve managed to find some bugs.
I will report the most frequent two.
The first is a home/lock screen related bug, if you follow this step you can reproduce:
0) turn all your alarms off
  1. set an alarm
  2. when it ring postpone it
  3. now go in the alarms section and turn it off
  4. you’ll see in the home screen an active alarm while all are turned off
(this works for me, there is a chance that for your device might not work)
The second bug, isn’t properly a bug, i noticed that on whatsapp you can’t turn the audio volume on or off with the lateral buttons (while listening to audios or other media that have audio), it triggers the ringtone’s one.
Since this is an issue related to a sideloaded app i don’t think there is something to do.
Anyway i’ve been loving the Kompakt.:grin:
@alegoduz Thank you for the feedback. I will pass this on to the team.
I’m not sure they will be able to do anything regarding the WhatsApp issue, but the other one, I’m sure they will look into.
Hi @alegoduz I could not duplicate the problem - I tried 3 methods, when I postpone (snooze) the alarm and then turn off the alarm in the app and return to the home screen, the alarm setting time is not showing. Maybe you used a different method?
Test 1 - from home screen set as no repeat, single time alarm
On the home screen I tap on the current time, the alarm app opens, set the alarm, set as don’t repeat. When the alarm sounds I tap snooze, open alarm app, turn off alarm (slider), return to home (center O function), home does not show alarm set on home screen.
Test 2 - set as alarm time as repeat daily
Set new alarm as “Repeat”, return to home screen (shows time alarm set), alarm sounds, tap snooze, open alarm setting, turn off alarm (slider), return to home, do not see alarm set display.
Test 3 - set alarm via Apps/Alarm
Set Alarm via menu Apps, alarm sounds, snooze, open alarm setting via menu Apps, go to Alarm via menu, turn off alarm (slider), return to home screen, see no alarm set
Thanks, for the feedback, i’ve forgot to say that the alarms that do this are repetead 2 day after.
Example alarm x repeats on monday (and other days after) and i witness this bug at saturday. Also the next time i get it i’ll try to record a video. Thanks.
EDIT: also the one’s that shows is not the one i postponed but another one
I’m not sure exactly how I got the glitch, but I am having the same issue where an old alarm is still showing on the lock screen. However, this alarm is no longer present anywhere, and I cannot remove it. Is there a way to clear all alarms and start from scratch? I think that might be the only way to remove this “ghost” alarm
