I normally use 1Password for securely storing personal info. It isn’t available as an apk, so I’m looking for a solution for an apk that supports encrypted storage of notes and account info (just for lookup, no integration). When I’m traveling I often need account info or other sensitive data, and I don’t want to write it down. I may not have ready access to a computer, so a bootable thumb drive won’t always work. Ideas are appreciated.
I installed 1Password from the Aurora Store and it works fine.
That’s good news. I contacted 1PW tech support and they didn’t mention the Aurora store. Do I sideload the Aurora store app and then get 1PW in app? New to Android.
Keepass works great on the Kompakt.
They won’t mention AuroraStore because nobody posts on AuroraStore.
AuroraStore is just an OpenSource frontend of PlayStore, the APK “links” come from Playstore, it’s just that you don’t have to give Google your credentials and can download them anonymously.
Yes. Or you can do what I did: sideload F-Droid and install the Aurora Store from there; then you have access to all of the apps in both.
