Simple Weather for Kompakt?
I am not a developer (any more) but would love to see this great app appear on the Mudita Kompakt:
SimpleWeather - SimpleAppProjects/SimpleWeather-Android: A simple weather application for Android
It’s clean, working with many Weather APIs (inc Tommorrow.io my personal favourite). Would anyone be willing to help port and optimise for the Kompakt? Happy to help where I can.
Hi! Could you tell me what is missing from the default weather app provided by Mudita? I do miss some rain statistics for my rainy country, but other than that I do quite like it! if there is demand for an improved weather app, I’d be happy to pick that up.
Fair question: I miss the hyperlocal information that tomorrow.io offers. Hour by hour visuals as to when the weather will change etc. Plus, to me, is a simple/sleek all informative client.
Can I use the tomrrow.io APIs with the default Mudita app?
To be fair to the dev, there is a non-gms build available:
I guess the missing part is adding the MMD design principles to it.
There are hour by hour visuals with icons (not really too indepth with rain analysis or anything like that).
No, that you can’t.
I might consider making a rain app for your GPS location, which shows it properly in a graph over time, but I am working on some other apps right now so. it might take some time. I do recall that some other dev on the forum made a rainmap already. Maybe that + the mudita app would meet your needs?
Thanks :slight_smile:
… but that’s my point. Why have two apps, when one goodone would be enough.
Out of interest, did the glitch with the stock weather app widget in settings not updating get fixed for those who got the 1.6 update?
Sky may cover some of this. It’s a fork of kRadar, the rain map mentioned above, with an Open-Meteo forecast beside it, so the radar and the forecast are one app: Today, the five days after it, and the radar, on three tabs.
After reading this thread it gained the next twelve hours under today: one line saying when rain is likely to start or stop and how much, over the hours drawn as bars. Each day now gives how much rain is expected, not only the chance.
The forecast is Open-Meteo’s alone, which needs no key or account. Tomorrow.io would need everyone to sign up for a key of their own, so it isn’t there.
If you have a weather station, Sky reads that too, and it leads Today.
@berendcsliedrecht, if you do build the rain graph, it would be good to compare notes rather than both make the same thing.
I installed the de-Googled version of Simple Weather on my Kompakt. It works.
  • I have an Api key to Tomorrow.io
  • The UI/UX brings a level of familiaity to me, having used it for so many years.
  • It’s not e-ink optimised, but it’s not awful looking.
Thanks you to all that helped here. Keep up the good work and geekery :slight_smile:
I think it just needs to give you more information, like the percentage change of rain and the ‘feels like temp’, especially for me here in Canada. I just find as is when its a picture of rain cloud that does not tell me much if for example I am going hiking. Then I have to go to my laptop and check the weather which I don’t want to do cause they could cause me to fall into a time wasting loop on my laptop.
I am curious how users like this app:
It’s made for outdoor sports (specifically) and since I’m not much into outdoor sports, I haven’t tested it personally.
Thanks for pointing to the KompaktWind app @urszula :slight_smile:
i just released a big update on the app with a lot of new features and improvements. Hopefully this is useful to someone else than me!
Check your DMs
