Silencing Vibration
Is there a way to turn off vibration for text notifications? I go to bed later than my partner and sometimes I am finishing a text conversation and although the volume is turned down all the way, it still vibrates and I don’t want to wake her up! I also want to avoid being disturbed while I sleep without having turning on Offline+ mode.
System > Developer Options > Search: Vibration Vibraton then click on it and turn it off.
This will turn off all the notification vibrations.
More info: Developer options is not turned on by default, search the forum or google how to turn it on.
@gezimos thanks so much!
mine vibrates with alarm in the morning (which is counter to the idea of nice gentle alarm sound). This would be a good fix - along with the fact that the screen brightness is extreme at the low end. It really is a magical product and so glad you are working through the newness …i simply cannot imagine owning any other phone!
Thank you so much for the feedback & the kind words. I will pass your suggestions & feedback to the team.
And…Welcome to the Mudita Forum :slight_smile: We’re glad you’re here!
Many thanks. I would also like to refloat the idea of having ay least one option for a brightly coloured case - maybe a limited addition run? To me, the idea of an orange which is the same as the offline orange would work great and also promote the more more offline / more life thing.
@darren1576 I’ll pass it on :slight_smile:
The more voices that louder the request
I’m still on team PINK
A post was merged into an existing topic: :right_arrow: Planned: Turn off vibration for alarms
