I would like to recommend another great minimalist launcher specifically designed for the Mudita Kompakt. It is called Sexy Launcher. Sexy Launcher on GitHub
I do not see it mentioned in any topic, so I will briefly give my impressions of the launcher after two weeks of use, and yes, I compare it to inkOs, as it is, in my humble opinion, the “gold standard” for launchers on the Mudita Kompakt.
So “Sexy Launcher” is a GREAT launcher, and I hope the developer gets support and keeps working on the project. I think, at this moment, it is not as ripe or mature as inkOs, but seeing the updates arrive at a lightning-fast pace, it can change at any moment. I think inkOs shines in customization; Sexy Launcher has far fewer options to fiddle with. On the other hand, the notification system, I think, works better on Sexy Launcher. I use URL Radio and Outer Tune as music apps on my Kompakt. The widget on “Sexy Launcher” works perfectly with both apps: the widget opens on the home screen, I can control my music, and I can even close the app.
So: I encourage everyone to try and explore “Sexy Launcher.” It works perfectly on MK, the notification system is great, but it lacks customization options.
