Ruhezeiten review by lisa
Ruhezeiten β€” Community App Review
Version: 1.0.0
Ruhezeiten adds scheduled quiet hours (Do Not Disturb) to the Kompakt since Mudita has not yet released this feature. Set a daily start/end time, and choose what still gets through: Priority only (alarms, plus starred contacts), Alarms only, or total silence. No root required, no accounts, no network access at all.
Simple app designed specifically for e-ink and the Mudita Kompakt using Mudita Mindful Design (MMD).
Review updated by @lisa
  • Known Issues updated
  • Author Rating: 5 β†’ 1
View current review
  • Version: 1.0.0 β†’ 1.1.0
  • APK Link: https://github.com/snoozetown/ruhezeiten/releases/download/v1.0.0/ruhezeiten-1.0.0.apk β†’ https://github.com/snoozetown/ruhezeiten/releases/download/v1.1.0/ruhezeiten.apk
  • Author Rating: 1 β†’ 3
  • Checksum: 1180ff2c354c604954d74e91e298db53a2c23113bbf764491903fdda43d3ad61 β†’ 735d1d4b0fddf10026e5da3560e1c55b74af702f36df09d5d01b15956cc504ef
View current review
Review for version 1.1.0
Author’s rating: β˜…β˜…β˜…β˜†β˜† Β· Author of this review
IMPORTANT: Follow installation instructions in the README or Ruhezeiten will not work correctly
Source: snoozetown / ruhezeiten
  • Author Rating: 3 β†’ 5
View current review
View current review
User rating: β˜…β˜…β˜…β˜…β˜…
I have installed this and it seems to work great! I get notifications through out the day, and at night things are silent. When Favorite contacts call it still rings loud.
Thank you for making this, it solved my number one issue with the Kompakt.
Author’s rating: β˜…β˜…β˜…β˜…β˜… Β· Author of this review
I’m glad but kind of surprised this worked for you! There are definitely bugs to iron out, but I haven’t had time to work on it lately. I will try to get back to this in a couple of weeks. In the meantime, let me know if anything goes wrong. Thank you for testing!
DND mode didn’t let media through, but I have created a pull request on the github repo that has fixed that.
Oh thanks, I found the same problem!
Working perfect.
Thanks.
This works great, although it does block media and using touch tones on your phone while enabled. But, I’m able to silence all calls/texts except for favorites exactly as advertised.
Lisa added the media bypass this week but has not made a release with it yet; I made a build here:
It’s signed by my keys instead of Lisa’s so you’ll have to reinstall if you want it.
User rating: β˜…β˜…β˜…β˜…β˜†
I used it for 2 days. There were problems that no sound from device for calls or messages or music player. Even with manually setting the volume didn’t help.
Uninstalling this app didn’t help with sound problem. I had to factory reset the device to get sound working. After factory reset I didn’t install this app. This app is useful but this bug made me not to install it again.
It’s likely your device was stuck in do not disturb mode. inkOS launcher has a shortcut to the do not disturb mode settings, and you can turn it off from there. Or you can go to developer options and search for settings from that screen. Factory reset is a pretty nuclear option!
Ok. Thank you for addressing it.
