Pretty simple, ability to change the names of devices. It’s already possible to change the name of the mudita phone itself.
I’m just running into issues where my home and my work have the same bluetooth receiver, so they’re indistinguishable on my device list.
@passion7270 Thank you for the suggestion. This has been mentioned previously, but I have pinged the team again about this. In the meantime, our devs said that If you’re familiar with ADB, you can do it via command prompts.
On most Android devices, the Bluetooth name is stored in global settings.
Just please keep it mind that it can be reset with every restart of Mudita Kompakt & MuditaOS K update.
Here’s are the prompts:
adb shell settings get global bluetooth_name
If this returnsnull, try checking the secure namespace instead:
