Repair and warrenty
Hi
I am looking at the repairbility of the Mudita Kompakt.
I can find the sparepart and the guide to change the sparepart eg. the battery.
However. By question is that on the spareparts is there a warning on void of warrenty, but that is not present in the guide. So do I void my warrenty if I change the battery myself?
Br,
Natasha
Link to support -
Battery Replacement (pdf link)
Thanks. Notice that there is no mention of warrenty void in the guide.
Dear @Natasha I am very sure opening the case yourself will void the warranty!
You should contact Customer Support at [email protected]
Do you know how or why the battery failed?
Hi
My battery has not failed. I just wanted to make sure whether the the warranty was void.
Just to prepare :slight_smile:
@Natasha Thank you for reaching out. You can purchase spare parts here:
Here is the link to self-installation guides:
Thank for your answer. But will it void my warranty if I change some parts myself?
I would encourage you to contact our customer support to get a clear answer for your specific case. If you purchased your device from Mudita & something is not working, it would be best to contact them first.
Hi
Thanks for the answer. I will reach out to support if I need to replace some part at some point :slight_smile:
