Recommend Charger
Good to know! In general, I understand using lower wattage chargers is the best for preserving battery capacity, since they cause less heat and therefore less degradation to the battery over time.
So quick chargers are useful when necessary - but if you plan to charge the device overnight, a lower wattage charger is probably the best choice. Most people have one laying around from older devices.
@brendxn But, the truth is, we’re charging like once twice per week, max.
Thanks for confirming!
So I just received my NA kompakt and tried it with the wireless charger I used for my iphone (none of them are apple branded) and so far two of them work though it does say that it is charging slowly, I think I’ll put a magsafe ring on the case so it finds the right spot and as an add on it can be help on my car mount.
@pablose the position of wireless charging antenna is not directly in the middle, but a little lower. Make sure to try that :slight_smile: Hope that helps.
