Re-flashing the operating system
I would like to reflash the os onto a used mudita phone. Is it possible? If so is it difficult?
Right now it’s not possible as the bootloader is locked. The only way to do so is via the updater.
Ok. Just a hypothetical situation if I tried to reinstall it using the updater and it had been tampered with would the updater be able to identify it?
As far as I know there is no reinstall. Backup via center, factory reset, update via Center, download backup via center
