Proton VPN review by mudita2
Proton VPN — Community App Review
Version: 5.18.75.0
Free Swiss VPN with advanced security and privacy features.
Works mostly good on Kompact. Unfortunately the kill switch does not seem to be supported on MuditaOS K so you have to be sure you are manually activating and checking up on the VPN connection. There is no option for always on vpn or block connections without VPN in Mudita’s settings.
Review for version 5.18.75.0
User rating: ★★★★★
Possible to enable Always on VPN with adb:
You need to know if for you it’s ch.protonvpn.android or ch.protonvpn.android.reproducible
adb shell settings put secure always_on_vpn_app ch.protonvpn.android
adb shell settings put secure always_on_vpn_lockdown 1
To verify that the value changed :
adb shell settings get secure always_on_vpn_app
adb shell settings get secure always_on_vpn_lockdown
Reboot your phone, and it should work
How to test : Disconnect proton vpn and see if you still have internet, it should not be the case
