So i ran into connecting/sound-problems with the Mudita Kompakt when plugin wired headphones (with mic/Remote). Sometimes it sounded very thin, no bass, next time it worked well. Seems to be a connection-problem which is known to be fixed with a CTIA ↔ OMTP wiring adapter. However i found out that plug in the Headphones when Kompakt is in Connected-Mode solves the problem as well, maybe cause the devices own mic is activated then. Looking forward to future updates!
@Spaghettoteca I spoke to our team about this & the issue is probably because when you ENABLE the OFFLINE+ mode, one of the things that happens is that it cuts off power to the peripherals, microphones etc.
So, when Mudita Komakt is offline this prevents the headphone configuration from being detected correctly.
There is really no easy solution to this problem. Our team is exploring some options.
Thanks for the reply! i mean as soon as you know how to do its not a big deal, since afterwards you could still switch to offline+ and it wont affect the sound. So maybe it would make sense to put that in the manual or troubleshooting etc.
@Spaghettoteca I will pass this feedback on to the team. Thank you!
