Pairing smartwatch to their Kompakt? I hear it receives full notifications
I had a pixel watch, which wouldn’t work on degoogled devices, but have recently been looking into getting a new smartwatch, either Garmin or Samsung.
I’ve heard that folks who have paired with smart watches were able to receive notifications, at least on the Withings and Garmin watches. The only issue I’m seeing it Garmin Connect stops running in the background after an hour.
So, has anyone had luck with keeping their smart watch paired to the kompakt?
@spencersabo The one person on the forum, who, I believe has a Garmin watch is @kirkmahoneyphd. Maybe he can offer some insight?
My Garmin watch works perfectly fine with Kompakt. Syncs fine, and runs in the background with minimal battery waste (Kompakt battery routinely lasts 2 days instead of 3, but I’m fine with that).
I both completely disabled Duraspeed and disabled battery optimization just for the Garmin Connect app (not sure if this has led to my success in not having it stop running in the background since I also have not experimented with it too much).
Thanks for the response! That’s great to know. Does it also receive notifications? Specifically from third party apps?
I’ve also heard Garmin Pay works without google play services, and through the nature of how it functions, should be perfectly safe on a device like the Kompakt.
Absolutely, my Garmin watch is completely functional as it was with my previous iPhone. In addition, as I believe it is a unique function with Android phones, within the Connect app you can choose which notification the watch receives. I have had difficulties getting the caller name or number to show on phone calls, but I can accept or decline calls from the watch and dismiss notifications. With the help of a sideloaded Calendar app, I was also able to get my calendar to sync to the watch. Garmin Pay works as well.
EDIT: I also just tried the Garmin IQ app (to download new apps), and it also works perfectly fine.
For anyone following this,
  • I successfully got caller names to appear after switching from the built-in dialer to the Google Phone app (as much as I hate Google, after trying numerous phone and messages apps, theirs were the one that seemed to display best and work without issue).
  • One thing I found that doesn’t work in the Garmin Connect app is “Courses.” You cannot search for courses or find them on the app (I’m assuming this feature requires Google Services). However, you can find them on the Garmin Connect website, favorite them, and then use the app to send them to your watch.
Can you please share how did you managed to disable duraspeed and battery optimization for the garmin app?
Duraspeed is in the developer settings. You can search for it, and then open it and disable Garmin Connect. That’s the one that made the difference in terms of staying connected all the time for me
@kezo Just like @spencersabo said, for Duraspeed, going to the Developer Settings, click the search glass icon, and typing in, “Duraspeed” seems to work great. BTW, side note, I’ve also experimented with turning Duraspeed completely off. Can’t say I noticed much of a difference either way, so I just keep it on (figure stick to default settings as much as possible and hope for optimal results).
As for battery optimization, I have been using the Activity Manager app (Activity Manager | F-Droid - Free and Open Source Android App Repository) to access most of those built-in but hidden settings (you can also acess Duraspeed through it). Once in the Activity Manager app, type, “Settings,” into the top search bar, and click on the Settings icon (com.android.settings). Click the search glass icon again and type in, “Optimization.” The second option should say, “Settings$HighPowerApplicationsActivity.” That’s the one! It’s also recommended to add podcast and music apps there. I’ve just come to accept that if I want my Garmin connected, I’m not going to easily sustain the 2-3 day battery life, and I’m fine with that. My battery charges to 80 every day, and after a normal day of work texts and syncing workouts, my battery is at 45% by end of day. I just suck it up and charge every night anyway.
I got a Polar Vantage V3 to work once I sideloaded Polar Flow, connected the watch via bluetooth, and sync’d. It successfully receives notifications.
anyone tried a pebble watch?
It should work fine with the Rebble app. I use Gadgetbridge (which will also work with the Pebble watch) to sync with my Sony Wena 3 watch clasp. It works well for me.
This is the first I’ve heard of a Pebble Watch, but I love what I’m seeing!
Anyone here had success with a Samsung watch?
does casio watches app also work with the Kompakt?
