Obtainium review by falk
Obtainium — Community App Review
Version: 1.4.3
Obtainium is an app manager which allows you to enter links to releases of various other apps, managing installation and update of non-native apps.
From the github readme: “Obtainium allows you to install and update apps directly from their releases pages, and receive notifications when new releases are made available.” cf. https://obtainium.imranr.dev/
I have been using obtainium on my Kompakt for a while, and although I keep it minimal and have not tried many apps, all of those I tried installed and ran without complication. Managing apps is much more convenient than sideloading updates all the time. And a huge benefit of obtainium is that you get the apk’s directly from the original devs, and not via some middle service (like f-droid).
Review for version 1.4.3
User rating: ★★★★★
Great companion app for these open source projects on github, since it tracks releases – it’s what I’ve been using
User rating: ★★★★★
@falk:
Is it correct to say that the Obtainium app can see every app that F-Droid can see?
If yes, then have you found that you do NOT need the F-Droid app installed on a Kompakt that has the Obtainium app?
Dear @kirkmahoneyphd ,
I can confirm that “f-droid official” is among the sources from which you can find and install apps.
This means that you would not require the F-Droid app and can install from their apk repository anyways.
However, as I understand it, you then still install the apk’s from their servers, which F-Droid compiled - with all the advantages (availability) and disadvantages (trust intermediate third party).
Obtainium has had some GUI rework since my review, it is a bit fancier and looks more modern with tiles and rounded corners and the common overuse of swiping animations. However, it still works as it should on my kompakt (1.5.0).
Hope this helps!
User rating: ★★★★★
That definitely helps! Thank you! One fewer app needed!
