New clock face request - Harmony and Harmony 2
I love “faces” options in H1 and H2
Currently I see different options with time
like date, motivational messages and battery.
Best seems with date and battery, but there is no option with motivational messages and battery state (correct me if I am wrong).
If possible, I would love to see battery status above (on top of) time and motivational as-is, beneath time.
If this is not possible, then some sound message when battery is 20 percent and below.
@anon11367638 Yes, that’s right, right now, there is no option to see the battery status & have the quotes visible at the same time. I get where you’re coming from, you want to be able to know when you should charge your Mudita Harmony :slight_smile: However, did you know, when the battery gets low, the quotes automatically disappear & the battery indicator shows up with the info how much battery percentage is left (the marker is below 20% )
Hopefully this helps.
I don’t recall ever hearing about this, but solves the problem :smiley:
I can also acknowledge H2 has even more extreme battery time, but once it will come :smiley:
