Mushroom Journal — Community App Review
Version: 0.3.10
Mushroom Journal is a notebook. It records what you can see, and it does not tell you what you found.
There is no edibility field in it anywhere. What it does is let you write a mushroom down properly while you are standing over it — where it grows, the cap, the gills, the stem, the flesh, in any order and however few of them — take photographs into labelled slots, and add a note.
A shortlist narrows as you go, shown as what has not been ruled out. Everything you tap is checked against every mushroom it could apply to, so nothing stays on the list that your answers contradict. Where no published description says anything — the taste of most Amanitas, say — the list tells you it could not check.
At home you go back over the entry with the photographs in colour, add the spore print you set overnight, and send the find to somebody who can actually say, with the things you could not tell written out. When they tell you what it was, there is a line to write it on.
There is a month view of what is about now, the ones that hurt people included, and a page for each mushroom: where and when, what it is confused with and how to tell them apart, and a drawing to hold a real one against. Most of the drawings are traced from old public-domain plates, Peck’s New York reports above all. A word on any page can be looked up in a dictionary app such as Define.
The pack is Southern Appalachia, 132 mushrooms. Nothing in it has been checked by a mycologist, and every page says so.
Source, and its licence: GitHub - wanderwildwood/kinokocho: Mushroom Journal (茸帳 kinokochō) — write a mushroom down while you are standing over it, and work out at home what it might be. It narrows a list, never decides, and says nothing about eating one. · GitHub — GPL-3.0-only.
