MuditaOS K 1.3.0 Rollout for Kompakt Begins Next Week
I’ve had no issues with SMS except some that were blocked by the blocking feature misfiring. But RCS is also not common here. People use plain SMS and WhatsApp.
I also think people here should be a bit realistic. The Kompakt is an upgrade to a dumbphone, not a minimalist smartphone. If you ever used a real dumbphone, you would see that RCS also doesn’t work on it and would give similar issues. The calendar app in a dumbphone doesn’t have sync either. The MP3 player would also be barebones. Etc. Yes, the original duymbphones of the late 2000s had advanced features, but they’re not manufactured anymore.
@urszula It’s funny that the video about playlist management shows a sideloaded Whatsapp. You’re also fixing a bug for sideloaded message apps, apparently. Imho you should formally embrace the sideloading and give us - with disclaimer - access to notification settings and power management settings.
Hey, will there be any way to set a custom order for songs in playlists?
I have to rename every track to 1. … 2. … 3. … if I want to listen to albums on the MK. It looks like the songs are only in alphabetical order on the video. If you could add this feature, it would be awesome. I think it’s more of a priority than playlist folders right now.
@wander @clippy I only have experience with using Offline+ for short periods of time. Since this seems to be more of a carrier redelivery issue, perhaps the solution just changing how you use Offline+. What is your purpose for using it?
@wander and @dlsellers Have you tried creating your own APN? I found this: https://www.usmobile.com/apn-download
I agree! I’m looking forward to this feature as long as the music player is not able to sort by artist/album etc. I really hope they use a common editable file format for playlists like m3u but I fear this could not be the case. Let’s see what the update brings…
It was, unfortunately, a really bad typo from our side. It was not meant to be clickbait. Our apologies.
which day does the rollout begin?
Looks like today, release notes just appeared: Mudita Kompakt Software Release Notes
I know many people will have this question, so yes, first you will have to update to 1.2.0 then to 1.3.0
I don’t use the Offline+ switch, this is not a carrier redelivery issue
We really, really need voicemail notifications
@The It’s coming. Our team is working on it. It’s on the roadmap.
My most wanted features/fixes:
  1. CalDav support
  2. Fix group chats
  3. Bus support on Maps
  4. Voicemail
  5. Simple pomodoro app
  6. Notes sync with desktop app
  7. Simple timer app
Hello,
can you please give the information to the Team to make it possible to close all apps in background for safe the battery. Just an option like Kill Apps (that didnt work in 12.0. )
thanks!
Hello. Since the update I have a notification for a SMS that is not there when I open the app. How can I deal with that issue ? Thanls a lot.
Just updated to 1.3.0. Expected something from a music app, but nope. With a 20k+ track library – new playlists won’t save me. For those with 5–10 albums on the phone – good for you, I’m happy (but not from the bottom of my heart) :rofl:
I also have a lot of tracks, because I wanted to get rid of Spotify.
The next update should have folder organisation. That will resolve a lot. For me at least.
Exactly. All my albums are in their own folder. No chance I create playlist for them just to use the Mudita.
It’s getting downloaded!
For me, bluetooth fix will be great as I fail to get back to wired earphones, while I can have both my laptop and my phone connected at once over BT. :wink:
I believe keyboard mechanics won’t change now and won’t change quickly, I’m going to sideload something. Recently I began typing a lot and long-press for special characters and lack of proper autocorrect slows me down badly.
Mine still says its up to date at version 1.2.0
Are you guys listening to albums in alphabetical order? I couldn’t get it in album order without having to rename every track.
