Mudita Kompakt - SD card maximum capacity?
I was wondering what the maximum storage size of SD card is that I can put into the Kompakt. I want to order the largest capacity that will be supported, is there a limit?
@fffscala I’ll ask our team & get back to you.
Hi Urzula,
Just want to second this request. Would be interested in finding out if theres an estimated max capacity, or maybe suggested sd card to use with the Kompakt?
Not only maximum capacity, but minimum required ‘speed’ rating
@oceanos So far, our team has tested SD cards with a capacity of 512GB, but we’re looking to test higher capacities. Once that happens, I will pass on the info.
@kirkmahoneyphd When our team tested 512GB, they stated that they did not notice any lag.
Okay, let me clarify. Looking at several 512GB MicroSD cards at Amazon, I see several different “Up to” speeds: 100 MB/s, 160 MB/s, 180 MB/s, 200 MB/s, etc.
Which “Up to” speed should Kompakt owners buy so that the speed capability of the MicroSD card is fast enough for the speed capability of the Kompakt?
@kirkmahoneyphd Now, I understand what you meant about speed. :slight_smile: When I was talking about it with the team, we were talking about perceived speed, as in, if there is lag in accessing (and processing/opening) the info on the SD card. I know I have this issue with my BBQ10.
But now that you’ve cleared it up, I will go back with the question.
Would like to know too!
Thanks @Urszula, would love to know if 1Tb and 2Tb cards are supported when your team finds out
I saw a video on YouTube where 2 TB was working instantly without issues, but it was an external drive connected by usb-C on the bottom of the phone
@ethkinber I will pass this on to the team. I’m not sure if they had a chance to test this.
what is the answer to this :slight_smile: is 1tb possible?
@brtunaoz Our team never tested 1TB SD cards. The max we tested was 512GB.
I threw in a 1 tb micro sd card, works fine.
@graysonhammon That’s awesome! Good to know!
Did you ever hear back on the speed question? I have an A1 larger SD card and a much smaller A2 SD card and am trying to decide if it is worth to use the A2 instead if I plan to set it for storage and to put apps on it
@pablose Out team also tested 1TB & it works fine. 2TB also works fine. I’ not sure what you mean about speed though. Can you please be more specific?
I know an A1-class SD card provides a minimum of 1,500 IOPS (Input/Output Operations Per Second) for reading and 500 IOPS for writing. An A2-class card offers even higher performance, making applications run more smoothly.
Are you asking which one works better with Kompakt?
Thanks Urzula for your response, you got it right about my question on the speed, I have seen that in some android devices using an A2 class will result in the SD card unmounting and failing randomly because the systems don’t support it very well, but since I’d like to use it to expand the storage and have a couple sideloaded apps there I’m trying to make the best decision on which one to use. Has the team tested both classes with the Kompakt? Is there a guidance to follow?
@pablose I asked the team. Let’s see what they say.
