If you tap on an entry in the Phone-Contacts list, you get the details editing page. If you want to call that contact, you then have to deliberately tap the “Call” button.
On the other hand, if you tap on the equivalent entry in the Phone-Recents list, then you initiate a phone call without having to tap any “Call” button. If you want to edit a recent contact, you have to tap the (i) icon next to the name (which then has a “Call” button).
The UI is unclear as both contact screens look rather similar and appear to have a similar function (listing contacts), and this leads a user to expect them to behave in similar ways, and they don’t. The two lists are different enough to learn how each list behaves, but the UI ought to be self-evident and not rely on user trial and error.
This has caught me out a few times when otherwise distracted, trying to find my glasses or just fumbling ineptly. In fact, there is no way of knowing of this behaviour the first time you use a Mudita Kompakt.
If the consequence of this mis-judgement was less than an accidental phone call, it wouldn’t be much of a problem, but accidental phone calls waste time and money and can cause confusion and I would rather not publicise my ineptitude to my contacts, some of whom are even more easily confused than I am.
Re: update to v1.6.1. Has this version been tested better than the last one (v1.6?). There were complaints about malfunctions and using users as beta testers, then that version was apparently pulled. I’m not installing v1.6.1 until enough time has passed for more adventurous users to beta test it for me.
Could you please describe the issues that you’re still experiencing and submit them to our tech support, so that our team can help you address the problems.
You can write directly to support at [email protected], if you feel that the support page is missing some options that you would like to include in report.
Hi; yes, I am a ‘he’ (not that I care much about that, really) and I did mean beta testing; that is, user acceptance testing with real users (who know what they’re doing) before the official release. I rather assumed that Mudita did their own alpha testing before users got their hands on anything, and users are not capable of doing alpha testing as this relies on internal knowledge of designs, what’s been changed etc. Urszula (above) states that the company have taken care that it works well; I took this to mean it had gone through some form of alpha testing.
It is usually bad practice for a tech company to use its paying customers as unknowing beta testers. The reputational damage may be considerable and unfixable.
