Mudita Kompakt minor suggestions
Hello,
I have been using Mudita Kompakt since first EU batch arrived. I really like its simple UI and great battery life. It mostly works for me without sideloading except for Organic Maps for navigation. However I have some suggestions.
Maps:
  • Allow longer trips. Now there is some limit for how long the route can be. I tried to navigate to place 600km away, and after few minutes of calculating I got an error. Organic maps does work for the same route.
  • Option to disable directions for when I should go straight. For example I am driving on highway and there is countdown to every single exit and straight direction when I reach it. This is distracting. Organic maps in comparison shows distance countdown only when you have to turn or in multilane situations in highway.
Contacts:
  • I am used to keeping my contacts saved on the physical sim card. This current works fine for reading. But I am unable to change or add new contacts to the sim storage.
I love the phone as it is, but with those minor inconveniences fixed it would go from 9.9 to 10 for me.
@david.murko Thank you so much for sharing your detailed feedback and for being with us since the first EU batch! We’re really glad to hear you’re enjoying the simple UI and battery life. Your suggestions about maps and SIM card contacts are very valuable, and I’ll make sure to pass them along to our team. It’s insights like yours that help us keep improving Mudita Kompakt.
We’re happy it’s already a 9.9 for you & we’ll keep working to bring it closer to a 10!
