Mudita Kompakt ,Good Battery Preservation Practice
unfortunately the Kompakt does not have Battery saving functions like restricting charge to 80% etc yet.
What is the best way to treat your Kompakt Battery well and get a long long life from this phone?
I have been told fast charging is bad for the Battery.
Adding some general tips:
  1. Turn off interface animations.
  2. Turn off vibration.
  3. Use Wifi whenever possible.
  4. Use Offline+ as often as you can.
Offline+ will be a gamechanger. I must think of moments in a day where I won’t be available for any emergency. Probably overnight and some deep focus moments at work.
