Mudita Harmony as Sunrise Alarm Clock?
Just wondering if the Mudita Harmony (1 and/or 2) is able to be used as a sunrise alarm clock? Does the light gradually turn on before the alarm, and is it bright enough to be used as a sunrise alarm clock? Thanks!
@domonation YES :slight_smile: Both of them have the option to light up BEFORE the alarm rings. You can also customize it as well- for how long, and should there be a sound along with the light or no sound & JUST LIGHT. You can also set the light intensity.
I have the Harmony 2 as an alarm clock and it’s very good. Minor gripes:
  • The light on the lowest setting is still quite bright. I have it set on the lowest setting and it doesn’t ‘fade up’ because of this.
  • The light color is cold light. My preference would be warm like sunrise.
Plusses: :smile:
  • Loading custom sounds. I have Brian Eno’s Ambient 1/1 as my alarm wake-up and I love it.
  • Battery power (no cord!) lasts 2-3 weeks using it in Relaxation mode nightly for ~30 mins.
@jmudita You might want to help us develop our next alarm clock:
I did the survey, yes. Thanks.
@jmudita Awesome!
