Mudita Harmony 2 Continuous Brown Noise
Sorry if this has been answered (recently) before, but I couldn’t find it in search.
I’m wondering whether the Harmony 2 can play the brown noise (or any sleep sounds or custom uploads) all night long, or whether there is a 90-minute limit before it shuts off? I am hopeful that I can use it as a white noise machine replacement, but that will be less of an option if the noise shuts off in the middle of the night.
@mudita3 Thanks for reaching out.
You can set the brown noise (or any other relaxation sound) on a loop. This means, that it will play continuously until you turn it off.
Hopefully this helps.
It does - thank you!
