what am I supposed to be able to do within Mudita Center when it comes to Contacts? I managed to import them (used Export Contact Pro on iOS to get a .csv file) , but when I imported that .csv file all that came in was firstname, lastname, and company. No phone numbers. no notes. nothing else. There is no document that tells me what columns need to be available on my .csv import
Then when the contacts are listed in Mudita Center 3.0.1 I can’t even edit them. I can edit them on my phone.
I’m using the Mudita Centre update for managing the Kompakt, are there plans to facilitate music management on there? I cannot seem to upload music, I am currently doing it through file management.
@jeremyarnold Our team has successfully imported contacts with note from CSV as well as from VCard.
Can we ask for an example contact? (you can send it in a DM) It can be unsupported content of the message, or CSV prepared by Export Contact Pro is incompatible with Android based phones. I’m attaching an example of supported VCard and CSV for reference of columns.
@simonepsp No, Mudita Center is not native for Apple. Our team has said that we do not plan to release a native version of the Mudita Center app for macOS that (works only with Macs) is optimized for Apple Silicon (M1/M2 chips) and does not require Rosetta 2 . We’re sorry if this might be an inconvenience.
@urszula So, it sounds as though the Mudita developers are only prepared to produce an Electron binary for the Mudita Centre app for the x86-64 architecture. Macs with Rosetta2 will run this, but with significantly degraded performance.
Why don’t they simply produce a binary for the Arm architecture? The underlying code would remain uniform. I don’t understand the reluctance. Please explain.
