MonoMusic — Community App Review
Version: 2.0.0
Hi all,
MonoMusic is my continuation of @davidray’s CalmMusic ( CalmMusic review by ArmchairSetup ).
All credit for the original app and its design goes to him; I have been building on that foundation.
MonoMusic is a music player for the Mudita Kompakt, built with MMD and designed for the e-ink screen. It plays your own music files and can search, stream, and download from YouTube Music. No account needed, no ads, no tracking.
Version 2.0.0 is out, and it is a big one. The core of the app was reworked:
- One queue for everything. Local files and streamed songs now play through a single player, so mixed queues flow smoothly from track to track, with shuffle and repeat working the way you expect.
- Songs keep their identity. Playlists survive moving files around, editing tags, and even reinstalling the app. Downloads carry their YouTube id inside the file itself.
- Albums fix their own ordering. Albums with missing track numbers repair themselves from the official track list, which matters a lot for albums that mix from one song into the next (Daft Punk’s Alive 2007 finally plays right).
- Your downloads are real files. They live in the Music/MonoMusic folder, on your SD card if you have one, visible in any file manager and safe across uninstalls.
- Cleanups. Older downloads are re-identified automatically, duplicate library entries are merged, and the floating overlay and battery optimization prompt were removed, so the app asks for fewer permissions and setup is a single step.
Requires Android 10 or newer.
Existing libraries and playlists migrate automatically the first time you open the new version.
If you find the app useful, you can support my work here: Sponsor @berendsliedrecht on GitHub Sponsors · GitHub
