MonoLights review by berendcsliedrecht
MonoLights — Community App Review
Version: 0.1.0
New application to control your Philips Hue lights using the Mudita Kompakt. It allows you to turn on/off lamps and adjust the brightness.
Setup is really simple. Open the app and your Mudita Kompakt will search for the Philips Hue Bridge. After that “pair” and then press the button on the Philips Hue Bridge. Once it is paired you can now easily manage your lights from your mudita kompakt!
If you like the apps that I create, feel free to buy me a coffee (V60 decaf please :wink:) via Sponsor @berendsliedrecht on GitHub Sponsors · GitHub.
