MonoFiles review by berendcsliedrecht
MonoFiles — Community App Review
Version: 0.1.0
Very simple file browser for the Kompakt, built with MMD. You can browse the storage, make folders and files, rename, copy, move and delete things, and
open files in whatever app can handle them (a downloaded PDF opens in the reader, an APK in the installer, etc). Fully offline, nothing leaves the device.
It asks for the “All files access” permission on first launch since that is what a file manager needs on Android.
I made it because the Kompakt does not really give you a way to see what is on the device itself (in an e-ink friendly/optimised way). It follows the same look as my other apps, so everything
stays black and white and e-ink friendly.
APK is on the releases page, debug-signed so you can sideload it directly. Happy to hear feedback, and if you are missing a basic file operation let me
know and I can add it!
If you like the apps that I create, feel free to buy me a coffee (V60 decaf please :wink:) via Sponsor @berendsliedrecht on GitHub Sponsors · GitHub.
Review for version 0.1.0
User rating: ★★★★★
Thanks for the app, having a good looking file explorer is great! I am just having one major issue: I cannot navigate to the SD card. I don’t know if it’s a problem with the app or with mudita, as the card is not properly shown in the settings (says 0 B capacity), but the android file explorer lets me use the card. Any way to handle this?
Review updated by @berendcsliedrecht
  • Version: 0.1.0 → 0.2.0
  • APK Link: https://github.com/berendsliedrecht/MonoFiles/releases/download/v0.1.0/files-0.1.0.apk → https://github.com/berendsliedrecht/MonoFiles/releases/download/v0.2.0/MonoFiles-v0.2.0.apk
  • Description updated
  • Checksum: 24ee33c2cac7ad95538de05560945adf4979cba77ab03f6aee7b4f9ea6b41a69 → 81bba4f7dc47368dd17fcc5db575520cc9ecca9890d315e410641957cff3eb9e
View current review
Review for version 0.2.0
Fixed it! You are now able to read the SD card as well!
User rating: ★★★★★
Thank you so much for the quick fix!! Works great!
