MK Sounds When Connecting Devices
Hi all,
I can’t find any consistency regarding MK sounds. When I connect my MK to my car via bluetooth, it makes the characteristic ding-dong sound. When I connect it to my computer (via USB-C) and enable debugging, it makes the same ding dong sound. At other times, I connect the MK to bluetooth audio devices around the home and there’s no sound. It’s inconsistent.
Sometimes the MK also makes the same sound and I can’t identify the trigger. (It’s possible that it’s a 3rd party Calendar event alert, but I can’t be sure).
@urszula, could you ask the team for an explanation please? Whenever I hear this mystery sound, it involves hunting round the device in various apps to identify where the alert is coming from. When there’s no answer, it’s tedious. When connecting devices, it’s inconsistent. Either make the chime with every connection or not at all.
Thanks.
I have a similar problem but with vibrations. Sometimes when I connect the Kompakt to my PC, it vibrates, but seldomly it doesn’t. It seems to be totally random.
I just asked them & are waiting for a response.
@petemeister Here’s a response from our team:
To give you an explanation of what is happening here:
1. The “Ding-Dong” Sound (Connection Alerts) The sound you are describing is the system’s default notification for a successful status change or connection event.
  • USB: When you connect to a computer with debugging enabled, the phone plays this sound to alert you that a data connection (ADB) has been established. This is a security feature to ensure you know a data link is active.
  • Bluetooth: This is where the inconsistency comes from. The sound is typically triggered when a device connects via a specific profile (like HFP/Hands-Free for your car or Headset profile). However, simple A2DP (Media Audio) connections often connect silently or handle the tone on the speaker itself, not the phone. This protocol difference is likely why your home speakers remain silent while your car (which acts like a headset) triggers the chime.
2. The “Mystery Sound”
  • If you are hearing this sound randomly without an obvious trigger, it is very likely a brief connection/disconnection event occurring in the background. For example, if your phone momentarily loses and regains connection to a known Bluetooth device, or if a charging cable has a loose contact, the system might play that same “Ding-Dong” to announce the reconnection.
  • It also comes from third party apps - we do not have notifications tray, so that can happen.
  • It also comes from unrecognized and unsupported group messages (in older Mudita OS K versions).
3. Your Suggestion (“All or Nothing”) You make an excellent point about consistency. Currently, MuditaOS separates “Charging Sounds” (which can be toggled in Settings > Sound > Advanced) from these system-level connection alerts, which do not have a user-facing toggle.
We agree that this behavior should be uniform—either always alerting or respecting a “System Sounds” toggle. We have logged your feedback as a feature request for our design team to review: specifically, to standardize connection sounds and give users the option to disable them entirely.
Brilliantly informative, @urszula. Thank you.
I have a similar issue where every time I’m on a phone call, there is an intermittent notification sound I may hear once or multiple times throughout the call. It doesn’t seem to have any consistent pattern, and it happens regardless if Bluetooth is on/off or WiFi on/off. It’s not my normal notification sound, it reminds me of the Apple sound when you initiate the microphone for talk to text. I also am usually stationary so I can’t imagine it’s a network connection issue. Any thoughts on what this sound is and how I can disable it? I have all the sounds disabled in the advanced settings, but I still do have some notification sounds like with charging or connecting to a computer.
@mgayden That’s so odd. Ever figure it out?
Nope I sure didn’t. Still happens some but not as often. Can’t figure out what the trigger is at all.
Hi @urszula, earlier in this thread you mentioned the following: “We have logged your feedback as a feature request for our design team to review: specifically, to standardize connection sounds and give users the option to disable them entirely.”
Is there a work package to achieve this in either the next OS update or the subsequent one? Has it even made it to the roadmap?
For now, I’m really holding myself back switching my sim back to my smart phone. The MK just won’t stfu. The mystery ding dong sounds are driving me batty. It’s like having a phone with paranoid schizophrenia. It suddenly gets spooked by ghosts, cries “Ding Dong” and when I look, there’s never any trace.
I find myself turning the volume off completely, which means I miss SMS/Signal messages.
Thank you.
Custom notifications are on the roadmap, and we will be updating it soon. Right not, I don’t know exactly when things will be implemented.
