Messaging review by wander
Review for version 1.33.7
User rating: ★★★★★
the app is still great and seems to be improving a lot with your constant updates. No issues while using it daily for me!
one suggestion that I have: could you change the voice message player? I sometimes use longer voice messages and at the moment there is no way of pausing them (just stopping them) and it would also be helpful to be able to skip in the voice message like the signal player allows it. And last thing, it would be great for listening to longer voice messages if a played voice message would not stop, when you lock the screen
Review updated by @wander
  • Version: 1.33.7 → 1.33.8
  • Checksum: 3b7af3e40771b7fcfed0d8aa35de41a6a08555731d6783fd0e89e3c95d4ee11c → 70531bfa193d8ad13afc5c5c1fb6194d56b49cfeaffac128a91f0d26bec01eee
View current review
Review for version 1.33.8
@hanswilli Thank you, glad it’s holding up. All three are in 1.33.8: a voice message now has a pause button and keeps its place when paused, a bar you can drag or tap to jump anywhere in it, and the time played. It also keeps playing with the screen locked or after you leave the conversation, and stops if another app plays sound or you start recording.
  • Version: 1.33.8 → 1.33.9
  • Checksum: 70531bfa193d8ad13afc5c5c1fb6194d56b49cfeaffac128a91f0d26bec01eee → 747c6c0f2d2387a2440c2533c9f0c7d2ae339d9945068f5241d7819d9ec5dc27
View current review
Review for version 1.33.9
User rating: ★★★★★
As always, very quick and perfectly working integration. Thank you so much!
User rating: ★★★★★
Hi Wander,
I have 2 things I found, but 1 of them I don’t really know what it is.
  1. When using Glance, it shows me messages in muted groups. Also, it shows me every message, not just the number of chats. So it says “8 Signal” when it is 8 separate messages in 1 group that I muted. It would be nicer if it would just show 1 notification for each unread thread and no notification for a muted chat.
  2. When I am typing a message and my phone vibrates (from a notification), the menu opens that usually opens when you hold the power button. I accidentally shut off my phone just now. This happened 2 times, but I don’t know why.
User rating: ★★★★☆
Forgive me if I’m asking questions that have already been asked, but I did try Ctrl-F and didn’t find what I’m looking for:
  1. Is there a way to make the messenger icon replace the SMS icon next to the phone icon instead of having to swipe right (twice in my case) to find the messenger app?
  2. Is there a guide for noobs to set up the Desktop Sync? I read the README and I guess it wasn’t explicit enough for me. And would there be a way to connect through USB?
  • Version: 1.33.9 → 1.33.10
  • Checksum: 747c6c0f2d2387a2440c2533c9f0c7d2ae339d9945068f5241d7819d9ec5dc27 → c89a6e83b8f2db6f84dbda230dc14efbf299e1f4c354c7d5b753d2e302fb3d1c
View current review
Review for version 1.33.10
@nico.n Thank you, both fair. Messaging 1.33.10 is up, and the card is updated. The lock-screen line now counts conversations with something unread rather than messages, so eight messages in one group is one, and muted chats are left out altogether, the same way their notifications are. It reads like “2 text chats · 1 Signal chat”.
The power menu opening while you type I haven’t found the cause of yet. Messaging never asks for that menu, so it may be the phone itself, but I’ll keep looking.
User rating: ★★★★★
Thank you so much!!
I am also not sure, I will ask Mudita as well. Maybe it is related to their keyboard. I thought it happened when the phone was vibrating.
User rating: ★★★★★
If this is outside the scope of Kotozute, i understand:
Is it possible for this app to “listen” to the Google Messages web client, so that it can effectively be used to send/receive RCS?
@Little-User Thank you. I’m going to say no to this one, kindly meant. Listening to Google Messages for web would mean the app quietly running Google’s web page in the background and reading it, which breaks each time Google changes that page, and needs your Google account signed in inside the app. RCS has no open way in for an app like this, so it carries SMS and MMS, and Signal for anything richer.
User rating: ★★★★★
No problem, thanks for considering it!
User rating: ★★★★★
Thank you for this brilliant app! I am using it every day on my Kompakt now, the ability to have both SMS and Signal in the same app is wonderful. Not to mention the e-ink optimisation which looks wonderful.
I did have a potential “bug” to report - I use my phone with a dual-SIM setup (one physical SIM, one eSIM), with the eSIM selected as default in the phone’s settings (Network and Internet > SIM Cards > SIM preferences). When I send an SMS, the app always selects the physical SIM as default despite this preference. I have forgotten a few times and ended up sending SMSs from the wrong number! I wondered if it would be possible to fix this issue at some point please?
Apologies as well if someone already mentioned this, I searched this thread and couldn’t see this. I am on the latest version (1.34.0) running MuditaOS 1.6.1. Thank you.
User rating: ★★★★★
This app is so good!! Signal integration exactly what i need to make this my only phone thanks!
to help with clutter it would be nice to have a “singles” list as the alternative to the groups list instead of “all” and “groups”. i could see the all being useful to some but it doesnt work with how i use signal very well. Happy to make it myself if you dont want to add it to yours! Hopefully im not just missing it in the options D: thanks so much for all your work!
Thank you, glad it’s working for you! It’s there, just tucked away in the options. In Settings, turn on “Show People instead of All” (before 1.34.6 it was called “Keep groups and unknown senders in their own tabs”). The first tab then becomes People, with only your one-to-one chats, and groups stay under Groups.
User rating: ★★★★☆
@wander , I think I found a bug. When I mark an sms conversation as unread, on the SMS icon on the home screen it shows the number of unread messages as 7 rather than one. Is it counting every message received from that contact instead of just the one conversation I marked as unread?
User rating: ★★★★☆
I have 1.34.o installed.
Ah! That’s probably because Signal sent a change downstream and I liked it and tried to copy it into the SMS rail. Give me a bit, I’ll fix this.
Thanks for letting me know!
@notabene Good news: it’s already fixed in 1.34.5, out now. Mark unread marks just the newest message, so the home screen counts 1. Opening that conversation once clears the old count of 7.
