Medicine — Community App Review
Version: 0.1.0
Medicine reminds you to take your medicines and keeps a record of what was taken.
Add a medicine with its name, how much, and when: at set times every day, on some days of the week, every few days, every few hours, or only when needed. At each time a reminder rings as an alarm does. With the screen off it fills the screen over the lock screen in large type, with the medicine’s notes under it, and Taken, Skip and Snooze work without unlocking. A dose that is not marked rings again after 30 minutes, up to three times; both can be changed.
Every dose that comes due goes into the log, marked or not. If the phone was off or the app was stopped when a dose was due, the log says no reminder rang, and the first screen says when the app was stopped. The log shows the last week and month of each medicine and can be shared as text or saved as a CSV file.
It can count what is left and say once when it gets low. The pharmacy, typed in or chosen from Contacts, is a Call or Text away, and the refill can go into the calendar.
On a Kompakt there is one step to do first: DuraSpeed shuts apps down when the screen is dark, which cancels their alarms. The first screen has a button that opens DuraSpeed, where Medicine is switched on. Settings has Try a reminder, which rings one in a minute to see how it looks.
It reminds; it does not advise. Nothing leaves the phone, and it has no internet permission.
Source, and the licence: GitHub - wanderwildwood/fukuyaku: Medicine (服薬 fukuyaku) — medicine reminders that ring on time, with Taken, Skip and Snooze on the lock screen, and a log of every dose. No internet. · GitHub — GPL-3.0-only.
How does the full-screen reminder suit you, or would a notification alone be better?
