Maps don't load an address (Kompakt)
Maps is better with the new ability to navigate, but that ability isn’t helpful if you can’t find the destination! I live in Bogota, and I am not able to enter an address. Maps will allow me to search the name of a place (and they don’t always appear), but I am not able to simply enter an address… this is pretty important. Hope we can see that ability soon! (P.S. I have downloaded the map for the area I’m referencing).
I live in the US and have had the same issue.
@alexandrafw & @jaks I have passed this on to the team. I think this might be because the addresses are sometime inverted,
When the address in Chicago should be 3505 N. Lavergne, it’s actually just shown as North Lavergne 3505.
Is there a plan to fix this? This is not how addresses are formatted in the US.
@andrewh I will ask out team what the plan is. They are aware of this issue.
UPDATE from the TEAM: They are working on making maps better & there will be improvements by the end of Q2 this year. Hopefully this helps.
Can you give us some more information as to what those improvements might be?
@astratev I will ask the team because I don’t know the specifics yet.
Just checking in to see if there has been any progress on this issue yet? I have just spent the last two days setting up my new Kompakt. I love it as an object, but have been having the same problem: cannot type in an address (USA) and have the maps app find the location. It keeps chopping off the house numbers (which must precede the street name, in USA), and so only sends me to some random spot on a road that is many miles long.
A suggestion: it would be great if there were a way to type the name of a contact into the maps search, and have the map app scrape the street address for that contact from the “Contacts” app.
Contacts in maps would be great, also manual origin destination, also prioritizing search results within 500 miles of the A-GPS location :joy:
Yeah the maps app isn’t great… I started using PaperMaps, which seems to work better, and faster too: Releases · davidraywilson/CalmDirectory · GitHub It’s still in Alpha testing but you could give it a try!
I’ve reached out to our team about this & I tried to reproduce what you’re experiencing, so I understand what’s happening. I’ll return once the team responds.
I actually found CalmMaps, and side-loaded it just yesterday (was not sure of an alpha release on the newer one). Worked like a charm today, getting me to a new dentist. Only the voice step-by-step was a bit delayed, but the printed step-by-step instructions were perfect.
I just wanted to chime in and say, that I spoke to our team and fixes to the native maps apps are planned for a future update.
