Hello, I have the newest OS14 on my Mudita Kompakt. But in order to use 100 percent of the time my Mudita I need Maps to work. Unfortunately it does not and shows me always GPS not available. Does someone have a solution. I would highly appreciate it.
Are you trying to use your maps inside?
Mudita Kompakt has a receive-only gps, which means that in order to work, it needs a clear view of the sky. So, you need to make sure you’re outside and give it a bit to catch the signal.
Thank you. Some times it works some times it does not outside. Maybe this is a point to make better with the next update. Kind regards
