Hi all.
The application keep crashing.
I have been using it since i bought the phone and now ( after update) its playing up.
I was wondering if anyone have same issue. Or if there is way around.
Thanks
have you checked its not being closed by the Battery Manager?
…battery manager? where can i find that?
settings > system > developer options > use search function in top right to search for Battery Manager > restricted Apps > untick any and all that you dont want it to close automatically.
done it (untick apk) , but the application still crashing.
it was ok before they made an update. now you need to buy licence and its useless… not sure if its only me
