KompaktX by jordan
KompaktX — Community App Review
Version: 1.1
KompaktX is an extended-feature overlay for the Mudita Kompakt.
The Kompakt is intentionally minimal out of the box, but that simplicity can introduce some friction in daily use. There’s no notification shade, no heads-up popups, eink refresh modes, app recents, and no way to import custom ringtones.
KompaktX fills those gaps with a lightweight layer designed specifically for eink. It sticks to pure black and white—no grayscale.
Core features:
Pull-down notification tray with multiple trigger options (edge swipe, pull-up gesture, or hardware button remap)
Heads-up notification popups with inline replies and action buttons
Quick toggles for Wi-Fi, Bluetooth, torch, brightness, and eink modes
Recent apps view (inline row or dedicated tab)
Hardware shortcut remapping (long-press or double-tap Recents, long-press Back, volume long-press for media skip)
Manual eink refresh button to clear ghosting on demand
Custom ringtone, notification, and alarm import
Light, Dark, and Follow-System themes (all pure black and white)
Per-app filters to hide noisy apps from the tray or recents
Review for version 1.1
Thank you for suggesting that! I asked if they can use that link instead. If they cant edit the icon link ill repost it :slightly_smiling_face:
User rating: ★★★★★
Amazing app! been using since release and it has greatly improved my functionality of the device! I love how nicely it works with the stock Mudita OS and it adds everything I was looking for without adding a bunch of extra stuff to get distracted by! great work!
User rating: ★★★★★
You should be able to edit the image yourself now, but I’ve gone ahead and replaced it for you!
Thanks for the great app! @jordan
Thank you! I’m glad your enjoying the app :slightly_smiling_face:
Thank you, I appreciate it :smiling_face_with_sunglasses:
User rating: ★★★★★
Hello, thank you for this fabulous app ! I really like it.
It missing only one little thing : can you add a button to toggle the localisation in the settings menu ?
It’s hard to acces in the stock mudita K Os. It would be nice to able to switch it rapidely.
Thank you again !
User rating: ★★★★★
Hi ! Thanks for this great work ! I have an issue… is it possible to have notification indicator on the lockscreen and/or on the homepage ; or must we pull the notification tray shortcut each time ? Probably it’s just a question of habit, and probably a good thing in order to keep the initial philosophy of the phone
Thank you! I would have added that but it seems theres no way to control that function without root unfortunately.
No problem! thank you. I honestly haven’t tried adding it on the lockscreen, It might be possible with placing the overlay somewhere but I was relying on inkOS launcher for the notification indicator since you can add a notification bell with a number count.
User rating: ★★★★★
Hi @jordan and KompaktX users - I’m having an issue with the heads up notifications displaying behind the status bar. This occurs with popup notifications associated with all apps and appears when any app is open, including the launcher/homepage. For what its worth, I’m also running Katapult. Any tips would be great!
User rating: ★★★★★
Either @jordan released an update or this problem spontaneously fixed itself. Hurray! I’m all squared away now.
User rating: ★★★★★
I don’t think this has been magically fixed. I have the latest version of the app, and I still see this problem.
User rating: ★★★★★
Interesting. Well, it is no longer affecting my device. Guess I got lucky?
Im glad its working ok now! I haven’t pushed any updates.
I just started working on fixing some bugs so I will test this and see if I can figure out why its doing that. Ill try to push a new update soon :slightly_smiling_face:
User rating: ★★★★★
The app needs the accessibility permission to draw over the status bar
Review updated by @jordan
  • Version: 1.1 → 1.2
View current review
Review for version 1.2
I made it more apparent in the kompaktX app when theres missing permissions so hopefully that helps people who are having this issue. It seems android will revoke permissions if you force close the app from app settings.
