Hello Mudita, I have a few suggestions to improve the already excellent Kompakt:
- The alarm volume should not work like all the other volume sliders. The old windows phones used to do it right: alarms were NEVER possible to be silent - after all, if I set myself an alarm, it’s because I want to hear it. Alarm volume should start quiet and increase gradually.
- If like to be avle to install (not necessarily have active) multiple esim profiles
- The darkest backlight setting is too bright. It should be possible to set it lower. When screen backlight is off, there’s no indication how to make it brighter again in the dark.
- If like to have the option to use the physical disconnect switch as either silent mode or flight mode. Let me choose.
- I’d like to be able to schedule do not disturb mode. I don’t want to have to disable notification sounds myself every evening.
Thank you for your consideration!
